Introdução
Use this guide to replace the LCD screen which is housed in the camera's back cover.
O que você precisa
Remove the following eleven screws securing the covers to the ZS3
Eleven 3 mm Phillips screws
Remove the two LCD board ribbon cables out of their sockets.
There are two ribbon cables: a wide one for the lcd display itself, and a thin one for the backlight. When reassembling, it is easy to reverse the polarity on the backlight cable, in which case the backlight will not work. Make a note of the polarity as you disassemble.
when I pried the small band's socket, the socket came off the board. What do I do now ? can I resolder it and where to ????
Take the back panel and use the flat end of the spudger to pry the LCD screen from the back cover.
3 outras pessoas executaram este guia.
2 comentários
It would be helpful if images of an inoperating screen were included. My screen shows many multi-colored lines - is it a broken screen or a bad board. The camera still shoots pictures.
Really useful guide. However, it's not quite complete: you do have to take the screen assembly apart once you've removed it from the back cover. It's not that difficult to do with the spudger, as all the metal bits around the screen just prise apart, but the 10-15 minutes quoted turned into an hour or so for me once I'd got it all back together again.
On some versions of this model, removing the back cover will suffice for this repair. The back cover is secured by only six screws.
Alex Levine - Responder
