Ir para o conteúdo principal
Panasonic Lumix DMC-ZS3 Battery Replacement
O que você precisa
  1. Panasonic Lumix DMC-ZS3 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Locate the small, hinged door on the bottom of the camera.
  2. Panasonic Lumix DMC-ZS3 Battery Replacement: passo 2, imagem 1 %32
    • Using your fingernail or a spudger, push the small, grey switch on the hinged door from the left (locked) to the right (unlocked).
    • The hinged door should swing open after unlocking.
  3. Panasonic Lumix DMC-ZS3 Battery Replacement: passo 3, imagem 1 %32
    • Using your fingernail or a spudger, push down on the small, grey tab holding the battery in place.
    • This should release the battery.
  4. Panasonic Lumix DMC-ZS3 Battery Replacement: passo 4, imagem 1 %32 Panasonic Lumix DMC-ZS3 Battery Replacement: passo 4, imagem 2 %32
    • Pull the battery out of the camera.
    • The battery should slide out easily.
Conclusão
Equipe
Cal Poly, Team 13-60, Johann Spring 2013 Membro de Cal Poly, Team 13-60, Johann Spring 2013
CPSU-JOHANN-S13S13G60
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Duração total: 1,291
