Introdução
Use this guide to replace the back cover of your Panasonic Lumix DMC-ZS3 camera, which houses the back panel buttons and LCD screen.
O que você precisa
Remove the following eleven screws securing the covers to the ZS3
Eleven 3 mm Phillips screws
Remove the two LCD board ribbon cables out of their sockets.
There are two ribbon cables: a wide one for the lcd display itself, and a thin one for the backlight. When reassembling, it is easy to reverse the polarity on the backlight cable, in which case the backlight will not work. Make a note of the polarity as you disassemble.
when I pried the small band's socket, the socket came off the board. What do I do now ? can I resolder it and where to ????
On some versions of this model, removing the back cover will suffice for this repair. The back cover is secured by only six screws.
Alex Levine - Responder
