Introdução
This guide will show you how to replace the speaker through a few steps.
O que você precisa
Remove the four 3.4 mm screws from the right and left sides of your Panasonic Lumix Camera.
Remove the two 2.6 mm screws located next to the battery.
Quase terminado!
Conclusão
Um comentário
In step 5, comparing it with the similar DMC-TZ35 I rather think there should be 3 screws, not 2. A 3rd hole can be seen at the bottom.
