Ir para o conteúdo principal
Panasonic Lumix DMC-ZS25 Flash Replacement
O que você precisa
  1. Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: passo 1, imagem 1 %32 Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: passo 1, imagem 2 %32
    • Using a small screwdriver, remove the four 3.4mm screws from the right and left sides of your Panasonic Lumix Camera.
  2. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 2, imagem 1 %32
    • Using a small screwdriver, remove the two 2.6mm screws located next to the battery, on the outer casing.
  3. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 3, imagem 1 %32
    • Using the plastic opening tool, open the outer cover of your device.
    • The easiest way to open your device is by placing the tool in the HDMI port.
  4. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 4, imagem 1 %32 Panasonic Lumix DMC-ZS25 Flash Replacement: passo 4, imagem 2 %32 Panasonic Lumix DMC-ZS25 Flash Replacement: passo 4, imagem 3 %32
    • Using the spudger, pull upward on the screen cable to release it.
  5. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 5, imagem 1 %32
    • Using the plastic opening tool, lift the button board until it clicks.
  6. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 6, imagem 1 %32 Panasonic Lumix DMC-ZS25 Flash Replacement: passo 6, imagem 2 %32
    • Using the plastic opening tool, lift the screen until it clicks.
  7. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 7, imagem 1 %32
    • Using a small screwdriver, remove the two 4.2mm screws located on the corner of the inner cover, under the screen.
  8. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 8, imagem 1 %32
    • Using the plastic opening tool, remove the inner cover.
  9. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 9, imagem 1 %32 Panasonic Lumix DMC-ZS25 Flash Replacement: passo 9, imagem 2 %32
    • Using your hands or the opening tool, separate the device into two pieces, as shown.
  10. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 10, imagem 1 %32 Panasonic Lumix DMC-ZS25 Flash Replacement: passo 10, imagem 2 %32
    • Using the spudger, remove the black side cover.
  11. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 11, imagem 1 %32
    • Using your hands, remove the front cover.
  12. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 12, imagem 1 %32 Panasonic Lumix DMC-ZS25 Flash Replacement: passo 12, imagem 2 %32 Panasonic Lumix DMC-ZS25 Flash Replacement: passo 12, imagem 3 %32
    • Using the spudger, unlock the screen cables from the circuit board.
    • Lift up the black clip to release the cables.
  13. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 13, imagem 1 %32
    • Using your hands, remove the lens.
  14. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 14, imagem 1 %32
    • Using the plastic opening tool, pull up on the edge of the circuit board until it clicks.
    • Remove the board.
  15. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 15, imagem 1 %32
    • Using a small screwdriver, remove the 3.7 mm screw near the green chip inside the camera, as shown. This will release the top of the camera.
  16. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 16, imagem 1 %32 Panasonic Lumix DMC-ZS25 Flash Replacement: passo 16, imagem 2 %32 Panasonic Lumix DMC-ZS25 Flash Replacement: passo 16, imagem 3 %32
    • Using the opening tool, pull up on the edge of the top cover to unlock it.
  17. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 17, imagem 1 %32 Panasonic Lumix DMC-ZS25 Flash Replacement: passo 17, imagem 2 %32
    • Using the opening tool, remove the top board.
  18. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 18, imagem 1 %32 Panasonic Lumix DMC-ZS25 Flash Replacement: passo 18, imagem 2 %32
    • Place the tip of the spudger at the edge of the top board, and work around three sides to loosen it.
    • Using the opening tool, lift up the top board. Now you will be able to safely remove the flash.
  19. Panasonic Lumix DMC-ZS25 Flash Replacement: passo 20, imagem 1 %32
    • Remove the old flash, and put in the replacement.
Conclusão
Abbas Khan
Membro desde: 01/21/15
482 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 9-5, Brown Winter 2015 Membro de USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 435
