Ir para o conteúdo principal
Panasonic Lumix DMC-ZS25 Screen Replacement
O que você precisa
  1. Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: passo 1, imagem 1 %32 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: passo 1, imagem 2 %32 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: passo 1, imagem 3 %32
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Screen Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to open the outer cover of your device from the HDMI port.
    • Open it carefully to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Screen Replacement: passo 3, imagem 1 %32 Panasonic Lumix DMC-ZS25  Screen Replacement: passo 3, imagem 2 %32 Panasonic Lumix DMC-ZS25  Screen Replacement: passo 3, imagem 3 %32
    • Use a spudger to carefully detach the ribbon cable without breaking it.
  4. Panasonic Lumix DMC-ZS25  Screen Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to lift and remove the buttons board as shown.
  5. Panasonic Lumix DMC-ZS25  Screen Replacement: passo 5, imagem 1 %32 Panasonic Lumix DMC-ZS25  Screen Replacement: passo 5, imagem 2 %32
    • Carefully lift the screen using the plastic opening tool as shown.
Conclusão
3 outras pessoas executaram este guia.
Abbas Khan
Membro desde: 01/21/15
482 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 9-5, Brown Winter 2015 Membro de USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
Membros da 3
Autoria de 7 guias
Um comentário
- Of the two 2.60 mm screws on the bottom of the camera, only the one closest to the back needs to be removed.
- The correct screwdriver is JIS Type S #00. A Phillips driver can ruin the screws.
- The screen shown in step 5 consists of two parts: the LCD and a frame. The replacement LCD that I ordered came without the frame, so a little more disassembly was required, including a bit of delicate soldering: the narrow ribbon cable is really two cables, soldered together. The solder joints are hidden under the piece of black electric tape at the end.
nasorenga - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 7
Duração total: 4,370
