Ir para o conteúdo principal
Panasonic Lumix DMC-ZS25 Lens Replacement
O que você precisa
  1. Panasonic Lumix DMC-ZS25  Lens  Replacement, Camera lens: passo 1, imagem 1 %32 Panasonic Lumix DMC-ZS25  Lens  Replacement, Camera lens: passo 1, imagem 2 %32 Panasonic Lumix DMC-ZS25  Lens  Replacement, Camera lens: passo 1, imagem 3 %32
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to open the outer cover of your device.
    • The easiest place to open your device is from the HDMI port.
    • Gently open it to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 3, imagem 1 %32 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 3, imagem 2 %32 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 3, imagem 3 %32
    • Use a spudger to detach the ribbon cable.
    • Be careful when using the spudger, as it can cause damage to the ribbon.
    • After releasing the screen cable, use the iFixit opening tool to lift the button board.
    • Once you hear a "click" sound, you have successfully opened the buttons board.
  4. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 4, imagem 1 %32 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 4, imagem 2 %32
    • Remove the screen using the iFixit opening tool.
  5. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 5, imagem 1 %32 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 5, imagem 2 %32
    • Open the two 4.20 mm screws to remove the inner cover located beneath the screen.
    • Use the iFixit opening tool to assist in safely removing the inner cover.
  6. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 6, imagem 1 %32 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 6, imagem 2 %32
    • Separate the device into two pieces as shown.
  7. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 7, imagem 1 %32 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 7, imagem 2 %32 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 7, imagem 3 %32
    • Remove the side cover using the iFixit opening tool.
    • Exercise caution when you remove the front cover as damage to the device can occur.
  8. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 8, imagem 1 %32 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 8, imagem 2 %32 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 8, imagem 3 %32
    • Use the spudger to unlock the screen cables from the circuit bored. Carefully, lift up the black clip up to release the cables.
    • Use your hands to remove the lens.
Conclusão
Abbas Khan
Membro desde: 01/21/15
482 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 9-5, Brown Winter 2015 Membro de USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 2,457
