Ir para o conteúdo principal
Panasonic Lumix DMC-TZ5 button board Replacement
O que você precisa
  1. Panasonic Lumix DMC-TZ5 button board Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the battery and memory card from the device.
  2. Panasonic Lumix DMC-TZ5 button board Replacement: passo 2, imagem 1 %32
    • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
  3. Panasonic Lumix DMC-TZ5 button board Replacement: passo 3, imagem 1 %32
    • Remove the single 3.4mm screw on the left side of the camera.
  4. Panasonic Lumix DMC-TZ5 button board Replacement: passo 4, imagem 1 %32
    • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
  5. Panasonic Lumix DMC-TZ5 button board Replacement: passo 5, imagem 1 %32
    • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
  6. Panasonic Lumix DMC-TZ5 button board Replacement: passo 6, imagem 1 %32 Panasonic Lumix DMC-TZ5 button board Replacement: passo 6, imagem 2 %32
    • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  7. Panasonic Lumix DMC-TZ5 button board Replacement: passo 7, imagem 1 %32
    • Remove the back casing from the camera.
  8. Panasonic Lumix DMC-TZ5 button board Replacement, button board: passo 8, imagem 1 %32 Panasonic Lumix DMC-TZ5 button board Replacement, button board: passo 8, imagem 2 %32
    • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
    • Carefully remove the function switch cover. This unit snaps on and off.
  9. Panasonic Lumix DMC-TZ5 button board Replacement: passo 9, imagem 1 %32
    • Carefully unsnap the front logic board from the rear logic board using a spudger.
  10. Panasonic Lumix DMC-TZ5 button board Replacement: passo 10, imagem 1 %32 Panasonic Lumix DMC-TZ5 button board Replacement: passo 10, imagem 2 %32
    • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
  11. Panasonic Lumix DMC-TZ5 button board Replacement: passo 11, imagem 1 %32 Panasonic Lumix DMC-TZ5 button board Replacement: passo 11, imagem 2 %32 Panasonic Lumix DMC-TZ5 button board Replacement: passo 11, imagem 3 %32
    • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
    • This leaves you with the logic board and the top connection panel separate and free from the camera
Conclusão
Ben Canfield
Membro desde: 10/10/10
409 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 9-21, Regan Fall 2010 Membro de Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 5,595
