Introdução
Use this guide to remove the rear cover of the Lumix DMC-GX85 - either to replace a defective or broken display, or to get it out of the way so you can make repairs to other components.
WARNING: Ensure the camera is off before starting!
O que você precisa
Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
Turn the camera so the lens is facing down with the rear cover pulled back.
Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
