Ir para o conteúdo principal
Panasonic Lumix DMC-GF2 Front Cover Replacement
O que você precisa
  1. Panasonic Lumix DMC-GF2 Front Cover Replacement, Battery: passo 1, imagem 1 %32
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Front Cover Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-GF2 Front Cover Replacement: passo 2, imagem 2 %32
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: passo 3, imagem 1 %32 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: passo 3, imagem 2 %32 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: passo 3, imagem 3 %32
    • Using a Philips #00 screwdriver, remove six 2.69 mm screws located on the two short sides and on the bottom of the camera.
    • To loosen a screw, turn the screwdriver to the left. To tighten a screw, turn the screwdriver to the right.
  4. Panasonic Lumix DMC-GF2 Front Cover Replacement: passo 4, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove four black 2.69 mm screws from the front of the camera.
  5. Panasonic Lumix DMC-GF2 Front Cover Replacement: passo 5, imagem 1 %32
    • Using your hand, gently lift up the front cover and separate it from the camera.
Conclusão
Nicole Gerlach
Membro desde: 10/30/16
218 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 5-9, Williams Fall 2016 Membro de Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
Membros da 3
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 19
Duração total: 993
