Introdução
This guide requires careful handling of the camera's inner parts, including the ZIF ribbons that attach the back cover to the camera and the buttons that will be removed.
O que você precisa
On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
Push on the back panel buttons from the frontside of the back cover.
