Ir para o conteúdo principal
Panasonic Lumix DMC-G5 Motherboard Replacement
O que você precisa
  1. Panasonic Lumix DMC-G5 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove four JIS #000 screws from the bottom part of the camera.
  2. Panasonic Lumix DMC-G5 Motherboard Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-G5 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove two JIS #000 screws from both sides of the camera.
  3. Panasonic Lumix DMC-G5 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove two JIS #000 screws under the viewfinder.
  4. Panasonic Lumix DMC-G5 Motherboard Replacement: passo 4, imagem 1 %32 Panasonic Lumix DMC-G5 Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the viewfinder lid.
    • Then, remove the two JIS #000 screws on the viewfinder.
  5. Panasonic Lumix DMC-G5 Motherboard Replacement: passo 5, imagem 1 %32 Panasonic Lumix DMC-G5 Motherboard Replacement: passo 5, imagem 2 %32 Panasonic Lumix DMC-G5 Motherboard Replacement: passo 5, imagem 3 %32
    • Gently remove the back panel from the camera.
    • Unclip the ribbon cable from the motherboard using Wide Plastic Opening Tools and pull the cable gently.
  6. Panasonic Lumix DMC-G5 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Remove the JIS #000 screws on the motherboard.
  7. Panasonic Lumix DMC-G5 Motherboard Replacement: passo 7, imagem 1 %32 Panasonic Lumix DMC-G5 Motherboard Replacement: passo 7, imagem 2 %32
    • Unclip the ribbon cable using the Wide Plastic Opening Tool on the motherboard.
    • Gently pull out the cable.
  8. Panasonic Lumix DMC-G5 Motherboard Replacement: passo 8, imagem 1 %32
    • Pull out the motherboard from the camera.
Conclusão
Khairul Samsudin
Membro desde: 05/22/19
412 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team S1-G4, Harley Summer 2019 Membro de IUPUI, Team S1-G4, Harley Summer 2019
IUPUI-HARLEY-SU19S1G4
Membros da 3
Autoria de 8 guias
Um comentário
Dear Khairul Samsudin - this is great, thank you so much.
Can I ask about another classic repair for the Lumix G5?
As with many lumix cameras, the rear thumbwheel on the Lumix G5 is a weak point and frequently fails - usually the “push in” movement that should change functions failes in the “pushed in” position.
Plese can you see if you can create a “fix” for this? It classically fails at about year 2-3, when the camera is out of warranty and the repairs cost from Panasonic is more than a secondhand G5 on eBay will cost!
Best wishes - Paul in the UK
Paul C - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Duração total: 1,400
