Ir para o conteúdo principal
Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement
O que você precisa
  1. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement, Loose Digitizer Cable: passo 1, imagem 1 %32
    • Power off your device by locating the on/off switch on top of camera.
  2. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 2, imagem 2 %32 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 2, imagem 3 %32
    • Remove the screw located on the right side of the camera.
    • Remove the screw located on the bottom right of the camera, and remove the cover from the camera.
  3. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 3, imagem 1 %32
    • Remove the screw located on the base of the camera.
  4. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 4, imagem 1 %32
    • Pry the top part of the camera slowly. Be careful not to tear the digitilizer cable.
  5. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 5, imagem 1 %32 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 5, imagem 2 %32
    • Open the bigger clamp using a spudger or other tools. Repeat for the smaller clamp.
  6. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 6, imagem 1 %32 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 6, imagem 2 %32
    • Carefully take the thin ribbon and insert cable end into the latch. Do this for both sides.
  7. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 7, imagem 1 %32 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 7, imagem 2 %32 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 7, imagem 3 %32
    • Once the ribbon is placed into the latch, carefully close the clamps by lowering the clamp into a down position. Repeat this step for both sides.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 350
