Introdução
This guide will show you how to access and remove the photoreceptor from the camera. It features three ribbon cables that you should handle carefully due to their delicate nature. As always, you should take note as to what screws go where so that you do not cause internal damage to your device.
Ferramentas
Peças
Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
Locate and remove the silver 2mm screw on the protection panel.
Remove the three black 8mm screws that remain.
Proceed to remove the protection panel entirely.
Uma outra pessoa concluiu este guia.
