Ir para o conteúdo principal
Panasonic Lumix DMC-FX37 LCD Screen Replacement
O que você precisa
  1. Panasonic Lumix DMC-FX37 LCD Screen Replacement, Panasonic Lumix DMC-FX37 Disassembly: passo 1, imagem 1 %32 Panasonic Lumix DMC-FX37 LCD Screen Replacement, Panasonic Lumix DMC-FX37 Disassembly: passo 1, imagem 2 %32
    • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
  2. Panasonic Lumix DMC-FX37 LCD Screen Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-FX37 LCD Screen Replacement: passo 2, imagem 2 %32
    • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
  3. Panasonic Lumix DMC-FX37 LCD Screen Replacement: passo 3, imagem 1 %32 Panasonic Lumix DMC-FX37 LCD Screen Replacement: passo 3, imagem 2 %32
    • On the opposite side of the camera, remove the two 3 mm screws.
    • Remove the bottom side panel and place it with its respective 3 mm screw.
  4. Panasonic Lumix DMC-FX37 LCD Screen Replacement: passo 4, imagem 1 %32 Panasonic Lumix DMC-FX37 LCD Screen Replacement: passo 4, imagem 2 %32 Panasonic Lumix DMC-FX37 LCD Screen Replacement: passo 4, imagem 3 %32
    • Remove the front panel (the panel around the lens casing) from the camera.
    • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
    • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
    • Remove the back panel from the camera.
  5. Panasonic Lumix DMC-FX37 LCD Screen Replacement: passo 5, imagem 1 %32
    • Remove the top control panel (connected to the flash battery) from the camera.
    • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
  6. Panasonic Lumix DMC-FX37 LCD Screen Replacement, LCD Screen: passo 6, imagem 1 %32
    • Use a plastic opening tool to pry off the LCD screen.
    • There is a small amount of adhesive lining the inside edges of the LCD screen. If you are having trouble prying off the screen, apply a small amount of heat to the front of the screen to melt the adhesive.
Conclusão
Ben DuBose
Membro desde: 01/30/18
327 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S2-G3, Johnson Spring 2018 Membro de Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 409
