Ir para o conteúdo principal
Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement
O que você precisa
  1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Battery: passo 1, imagem 1 %32
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
    Pergunte ao FixBot
  2. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 2, imagem 2 %32
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
    Pergunte ao FixBot
  3. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Memory Card: passo 3, imagem 1 %32
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
    Pergunte ao FixBot
  4. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: passo 4, imagem 1 %32 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: passo 4, imagem 2 %32
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
    Pergunte ao FixBot
  5. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 5, imagem 1 %32 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 5, imagem 2 %32
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
    Pergunte ao FixBot
  6. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 6, imagem 1 %32 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 6, imagem 2 %32 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 6, imagem 3 %32
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
    Pergunte ao FixBot
  7. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 7, imagem 1 %32 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 7, imagem 2 %32 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 7, imagem 3 %32
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
    Pergunte ao FixBot
  8. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: passo 8, imagem 1 %32 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: passo 8, imagem 2 %32
    • Gently wiggle out the top motherboard.
    • The buttons are hardwired into this logic board.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
Karissa
Membro desde: 04/13/12
71 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 6-23, Amido Spring 2012 Membro de Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 64
Ao todo: 1,210
