Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Move the switch on the battery door to the Open position.
Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
Keep your finger clear of the battery when it pops out.
Push the memory card in and let go.
Pull out the memory card.
Unscrew the small screws on the sides of the camera.
Unscrew the three small screws on the bottom(#00P, 3.3mm).
Lift up the bottom back cover by prying the bottom edge with the spudger.
Gently lift up the back cover with your hand from the bottom to the top.
Lift the tabs on the ZIF connectors.
The ribbon cables should easily come out of the ZIF connectors.
