Ir para o conteúdo principal
Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement
O que você precisa
  1. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Battery: passo 1, imagem 1 %32
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 2, imagem 1 %32
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 3, imagem 1 %32
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Rear Casing: passo 4, imagem 1 %32
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 5, imagem 1 %32
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 6, imagem 1 %32 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 6, imagem 2 %32
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 7, imagem 1 %32
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 8, imagem 1 %32
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 9, imagem 1 %32 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 9, imagem 2 %32
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, LCD Screen: passo 10, imagem 1 %32
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 11, imagem 1 %32
    • Gently tug the thicker ribbon to remove it from its housing.
  12. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: passo 12, imagem 1 %32 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: passo 12, imagem 2 %32
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  13. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 13, imagem 1 %32
    • Remove the two 3mm screws.
  14. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 14, imagem 1 %32 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 14, imagem 2 %32
    • Pry bars back gently as shown.
    • Fingers can be used but tool is shown for clarity.
  15. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 15, imagem 1 %32 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 15, imagem 2 %32
    • After, releasing all the components, gently remove the flash assembly from the casing.
  16. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 16, imagem 1 %32
    • Remove the 1.2 mm screw from the settings wheel.
  17. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 17, imagem 1 %32
    • Replace buttons.
    • Replace the "On/ Off" button with the prongs facing away from the flash.
Conclusão
Andrew
Membro desde: 10/11/10
396 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-22, Regan Fall 2010 Membro de Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
Membros da 4
Autoria de 8 guias
Um comentário
Olá ! Sugiro ter cuidado com a carga do capacitor do flash, melhor descarrega-lo com auxílio de uma lâmpada ou resistor
para evitar um choque elétrico.
Ricardo Britto - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 5,054
