Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Open the battery latch, and slide the battery release lever to the right.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
Gently remove the back casing.
Start at the bottom and carefully pry towards the top to get this piece free.
Gently lift up the LCD screen.
Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
It should fall out on its own or with a gentle tug.
Gently tug the thicker ribbon to remove it from its housing.
3 outras pessoas executaram este guia.
