Ir para o conteúdo principal
Panasonic Lumix DMC-FX01 Camera Lens Replacement
O que você precisa
  1. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Battery: passo 1, imagem 1 %32
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 2, imagem 1 %32
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 3, imagem 1 %32
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Rear Casing: passo 4, imagem 1 %32
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 5, imagem 1 %32
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 6, imagem 1 %32 Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 6, imagem 2 %32
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 7, imagem 1 %32
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 8, imagem 1 %32
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 9, imagem 1 %32 Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 9, imagem 2 %32
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: passo 10, imagem 1 %32 Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: passo 10, imagem 2 %32
    • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
    • There may be a third screw the the right of the lens assembly.
  11. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 11, imagem 1 %32 Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 11, imagem 2 %32 Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 11, imagem 3 %32
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  12. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 12, imagem 1 %32
    • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
  13. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: passo 13, imagem 1 %32 Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: passo 13, imagem 2 %32
    • Remove the three black 5mm screws attached to the lens frame.
  14. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 14, imagem 1 %32
    • Remove the lens frame.
  15. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 15, imagem 1 %32
    • Lift out the circuit board as shown.
  16. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 16, imagem 1 %32 Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 16, imagem 2 %32
    • Lift the two black latches that hold the connector ribbons in place.
    • Disconnect the two ribbons.
  17. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 17, imagem 1 %32
    • Remove the lens assembly as shown.
  18. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Camera Lens: passo 18, imagem 1 %32
    • Remove four 4 mm screws from the lens assembly using the Phillips #00 screwdriver.
  19. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 19, imagem 1 %32 Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 19, imagem 2 %32
    • Separate the fixed frame unit from the main lens assembly.
    • Separate the direct frame unit from the main lens assembly.
  20. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 20, imagem 1 %32
    • Remove the first lens frame from the lens assembly.
  21. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 21, imagem 1 %32
    • Detach the second frame unit from the lens assembly.
  22. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 22, imagem 1 %32
    • Remove the 4m m screw from the lens housing using the Phillips #00 screwdriver.
  23. Panasonic Lumix DMC-FX01 Camera Lens Replacement: passo 23, imagem 1 %32
    • Separate the lens housing.
    • Replace the lens by gently prying away from the assembly.
Conclusão
4 outras pessoas executaram este guia.
Caleb Fink
Membro desde: 10/11/10
191 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-22, Regan Fall 2010 Membro de Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 23
Duração total: 12,741
