Ir para o conteúdo principal
Panasonic Lumix DMC-FH20 LCD Screen Replacement
O que você precisa
  1. Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 3, imagem 1 %32 Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 3, imagem 2 %32
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
  4. Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 4, imagem 1 %32 Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 4, imagem 2 %32
    • Remove the white plastic cover. This may take some extra force. You will want to try to remove from the bottom side first and peel up.
    • Then, where the silver switch is located, it will slide directly out at the top.
  5. Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 5, imagem 1 %32
    • Unscrew one screw (Phillips #000 head).
  6. Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 6, imagem 1 %32 Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 6, imagem 2 %32 Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 6, imagem 3 %32
    • You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
    • Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
Conclusão
Uma outra pessoa concluiu este guia.
Arianna Boushell
Membro desde: 01/24/17
626 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 10-7, Banghart Winter 2017 Membro de Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 554
