Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Replacing the front case of your camera.
O que você precisa
Slide the lock switch to the right so that it is in the unlocked position.
Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
Place the camera on a flat surface with the front side facing down.
Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
Using Spudger tool, pry the front case from the camera's components.
Use your fingers to carefully pull the back case from the front case.
Cut the black and red wires connecting front case to the body of the camera.
Be careful to ensure that nothing gets caught, and separate the front case from the camera.
Uma outra pessoa concluiu este guia.
