Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement
O que você precisa
  1. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 2, imagem 1 %32
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
  3. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Back Case: passo 3, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
  4. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 4, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 5, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the two 2.8 mm screws on the side of the camera.
  6. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 6, imagem 1 %32 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 6, imagem 2 %32
    • Use a spudger to pry open the case at all sides.
  7. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 7, imagem 1 %32 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 7, imagem 2 %32
    • Be careful not to damage the ribbon cable when opening. Ensure it is still attached.
    • Use your fingers to carefully remove the back casing from the front of the camera.
  8. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 8, imagem 1 %32
    • Place the camera on a flat surface with the front side facing down.
    • Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
    • Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
  9. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Replacing LCD Screen: passo 9, imagem 1 %32 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Replacing LCD Screen: passo 9, imagem 2 %32
    • Use a spudger to lift the screen ZIF connector tab.
    • Use the back of the spudger to push the ribbon cable free.
  10. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 10, imagem 1 %32 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 10, imagem 2 %32 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 10, imagem 3 %32
    • Remove the four 2.4 mm Phillips screws as shown in picture.
    • Lift up the LCD screen from the front case.
    • Beware of the wire that is connected to the board in the other side.
  11. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 11, imagem 1 %32
    • Remove the LCD screen from its case.
  12. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: passo 12, imagem 1 %32
    • Desolder the wire connecting the LCD to the motherboard.
    • Solder wires from new LCD screen to the circuit board.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Penman
Membro desde: 01/28/11
463 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 7-35, Regan Winter 2011 Membro de Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 3,017
