Introdução
If you’ve cracked the screen or are experiencing issues with the screen of your Panasonic Lumix DMC-F7 digital camera, it may be time for a replacement. To complete this replacement, you will need to know how to solder. You will also need a few tools, so be sure to check the Tools List below before starting this replacement. This guide will help you properly replace the LCD (liquid crystal display) screen for the Panasonic Lumix DMC-F7 digital camera.
Peças
Nenhum componente especificado.
Slide the lock into the unlocked position to the right.
Use your finger to slide battery hatch towards the arrow sign.
Use a spudger to lift the screen ZIF connector tab.
Use the back of the spudger to push the ribbon cable free.
Uma outra pessoa concluiu este guia.
