Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Steps for removing the back half of the case and replacing it with a new one.
O que você precisa
Slide the lock switch to the right so that it is in the unlocked position.
Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
Lay the camera on its front side. Then, use the Spudger to open the film strip locking mechanism and remove strip.
Hold down on the camera's metal casing with one hand. Using your other hand, completely lift the back case off the rest of the camera, making sure the film strip separates.
Uma outra pessoa concluiu este guia.
