Introdução
Fixing the lens apparatus on your camera.
Ferramentas
Peças
Nenhum componente especificado.
Slide the lock into the unlocked position to the right.
Use your finger to slide battery hatch towards the arrow sign.
Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
Using Spudger tool, pry the front case from the camera's components.
Use your fingers to carefully pull the back case from the front case.
Cut the black and red wires connecting front case to the body of the camera.
Be careful to ensure that nothing gets caught, and separate the front case from the camera.
Uma outra pessoa concluiu este guia.
