Ir para o conteúdo principal
Panasonic KX-TGE233 Power Port Replacement
O que você precisa
  1. Panasonic KX-TGE233 Power Port Replacement, Base Front Panel Assembly: passo 1, imagem 1 %32
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 Power Port Replacement: passo 2, imagem 1 %32
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 Power Port Replacement: passo 3, imagem 1 %32
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 Power Port Replacement: passo 4, imagem 1 %32
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 Power Port Replacement: passo 5, imagem 1 %32
    • With the back removed, we now have direct access to all other components in the main docking station.
  6. Panasonic KX-TGE233 Power Port Replacement, Power Port: passo 6, imagem 1 %32
    • Now that the device has been opened, the power port can easily be removed from its resting point.
  7. Panasonic KX-TGE233 Power Port Replacement: passo 7, imagem 1 %32
  8. Panasonic KX-TGE233 Power Port Replacement: passo 8, imagem 1 %32
    • The faulty power port can now be detached from the device from its contact points. If soldering has been successful, removal should require minimal effort.
Conclusão
Nico Cruz
Membro desde: 02/09/16
249 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-2, Baechle Spring 2016 Membro de IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
Membros da 5
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 2,138
