Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
With the screws removed, you can use a spudger to aid in removing the back from the device.
With the back removed, we now have direct access to all other components in the main docking station.
