Ir para o conteúdo principal
Panasonic KX-T4000R Cordless Phone Antenna Replacement
O que você precisa
  1. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: passo 1, imagem 1 %32 Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: passo 1, imagem 2 %32
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Panasonic KX-T4000R Cordless Phone Antenna Replacement: passo 2, imagem 1 %32 Panasonic KX-T4000R Cordless Phone Antenna Replacement: passo 2, imagem 2 %32 Panasonic KX-T4000R Cordless Phone Antenna Replacement: passo 2, imagem 3 %32
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: passo 3, imagem 1 %32 Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: passo 3, imagem 2 %32
    • Find the silver screw located in the red circle.
    • Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
  4. Panasonic KX-T4000R Cordless Phone Antenna Replacement: passo 4, imagem 1 %32 Panasonic KX-T4000R Cordless Phone Antenna Replacement: passo 4, imagem 2 %32
    • Press the release button.
    • The release button is located in the red circle in the image to the left.
Conclusão
Elizabeth Kelly
Membro desde: 10/22/12
501 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 15-1, Benson Fall 2012 Membro de Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,883
