Introdução
Once the back cover has been removed, removing the antenna is as simple as unscrewing one screw.
O que você precisa
Orient the phone so that the phone model and other descriptive information is facing upward.
Locate the two silver screws near the hinge where the battery is housed.
Remove the silver screws using a Phillips head #2 screwdriver.
Find the silver screw located in the red circle.
Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
