Ir para o conteúdo principal
Panasonic KX-E603 Case Replacement
O que você precisa
  1. Panasonic KX-E603 Case Replacement, Case: passo 1, imagem 1 %32 Panasonic KX-E603 Case Replacement, Case: passo 1, imagem 2 %32
    • Flip the typewriter to expose the bottom body panel.
    • Be careful to not damage the top surface of the typewriter when you rest it upside-down.
  2. Panasonic KX-E603 Case Replacement: passo 2, imagem 1 %32
    • Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
  3. Panasonic KX-E603 Case Replacement: passo 3, imagem 1 %32
    • Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
    • Remove the three 19 mm screws near the bottom of the tan body panel using a Phillips #2 screwdriver.
  4. Panasonic KX-E603 Case Replacement: passo 4, imagem 1 %32 Panasonic KX-E603 Case Replacement: passo 4, imagem 2 %32
    • Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis.
    • Remove the two 19 mm screws using a Phillips #2 screwdriver.
  5. Panasonic KX-E603 Case Replacement: passo 5, imagem 1 %32 Panasonic KX-E603 Case Replacement: passo 5, imagem 2 %32
    • Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
  6. Panasonic KX-E603 Case Replacement: passo 6, imagem 1 %32 Panasonic KX-E603 Case Replacement: passo 6, imagem 2 %32 Panasonic KX-E603 Case Replacement: passo 6, imagem 3 %32
    • Remove the roller wheel adjustment knobs by pulling firmly outward.
    • Both black knobs must be removed in this step.
  7. Panasonic KX-E603 Case Replacement: passo 7, imagem 1 %32 Panasonic KX-E603 Case Replacement: passo 7, imagem 2 %32
    • Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
  8. Panasonic KX-E603 Case Replacement: passo 8, imagem 1 %32 Panasonic KX-E603 Case Replacement: passo 8, imagem 2 %32
    • While both spring levers are depressed, lift up with both hands to remove the roller wheel.
  9. Panasonic KX-E603 Case Replacement: passo 9, imagem 1 %32 Panasonic KX-E603 Case Replacement: passo 9, imagem 2 %32 Panasonic KX-E603 Case Replacement: passo 9, imagem 3 %32
    • Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 17-1, Forte Spring 2015 Membro de Cal Poly, Team 17-1, Forte Spring 2015
CPSU-FORTE-S15S17G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 377
