Ir para o conteúdo principal
Panasonic HDC-TM15 Side Cover Replacement
O que você precisa
  1. Panasonic HDC-TM15 Side Cover Replacement, Side Cover: passo 1, imagem 1 %32
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Side Cover Replacement: passo 2, imagem 1 %32
    • Next, unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Side Cover Replacement: passo 3, imagem 1 %32 Panasonic HDC-TM15 Side Cover Replacement: passo 3, imagem 2 %32 Panasonic HDC-TM15 Side Cover Replacement: passo 3, imagem 3 %32
    • By putting your hand through the hand-strap, tug on the side cover until it comes off completely.
    • Once the old cover is completely detached, set it aside.
    • The inside of your camcorder should now be completely exposed, as seen in the photos.
  4. Panasonic HDC-TM15 Side Cover Replacement: passo 4, imagem 1 %32 Panasonic HDC-TM15 Side Cover Replacement: passo 4, imagem 2 %32
    • Line up the new side cover in the exact same place, ensuring that the screw holes match.
    • Re-screw the side cover into place.
  5. Panasonic HDC-TM15 Side Cover Replacement: passo 5, imagem 1 %32
    • Gently tug on the hand-strap to ensure that the screws are tight and the side cover is secure.
    • When the side cover is securely fastened, you have completed the side cover replacement of your Panasonic HDC-TM15 camcorder.
Conclusão
Uma outra pessoa concluiu este guia.
Tricia Fallo
Membro desde: 03/11/15
210 Reputação
Autoria de 2 guias
Equipe
Marist, Team 1-4, Laflen Spring 2015 Membro de Marist, Team 1-4, Laflen Spring 2015
MARS-LAFLEN-S15S1G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 324
