Ir para o conteúdo principal
Panasonic HDC-TM15 Record Button Replacement
O que você precisa
  1. Panasonic HDC-TM15 Record Button Replacement, Record Button: passo 1, imagem 1 %32
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Record Button Replacement: passo 2, imagem 1 %32
    • Unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Record Button Replacement: passo 3, imagem 1 %32 Panasonic HDC-TM15 Record Button Replacement: passo 3, imagem 2 %32 Panasonic HDC-TM15 Record Button Replacement: passo 3, imagem 3 %32
    • Once all eleven screws have been removed, put your hand through the hand-strap and tug on the side cover until it comes off completely.
    • The inside of your camcorder should now be completely exposed, as shown in the photos.
  4. Panasonic HDC-TM15 Record Button Replacement: passo 4, imagem 1 %32 Panasonic HDC-TM15 Record Button Replacement: passo 4, imagem 2 %32
    • Unscrew the two 1 mm Phillips #00 black screws in the corners of the green memory card reader.
    • The screws should be surrounded by orange circles.
  5. Panasonic HDC-TM15 Record Button Replacement: passo 5, imagem 1 %32
    • Unscrew the black 1 mm Phillips #00 black screw in the left center beside the green motherboard.
  6. Panasonic HDC-TM15 Record Button Replacement: passo 6, imagem 1 %32 Panasonic HDC-TM15 Record Button Replacement: passo 6, imagem 2 %32
    • Unscrew the 1.2 mm Phillips #00 black screw beneath the motherboard on the bottom of the camcorder.
    • The green motherboard should now be partially detached, as shown in the photo.
  7. Panasonic HDC-TM15 Record Button Replacement: passo 7, imagem 1 %32 Panasonic HDC-TM15 Record Button Replacement: passo 7, imagem 2 %32 Panasonic HDC-TM15 Record Button Replacement: passo 7, imagem 3 %32
    • Remove the long silver plate that secures the record button.
  8. Panasonic HDC-TM15 Record Button Replacement: passo 8, imagem 1 %32
    • Remove the old record button from beneath the silver plate.
  9. Panasonic HDC-TM15 Record Button Replacement: passo 9, imagem 1 %32 Panasonic HDC-TM15 Record Button Replacement: passo 9, imagem 2 %32
    • Place the new Record button into the open slot.
  10. Panasonic HDC-TM15 Record Button Replacement: passo 10, imagem 1 %32 Panasonic HDC-TM15 Record Button Replacement: passo 10, imagem 2 %32
    • Slide the silver plate into place beside the new Record button.
    • Ensure that the Battery Eject button is lined up properly.
  11. Panasonic HDC-TM15 Record Button Replacement: passo 11, imagem 1 %32 Panasonic HDC-TM15 Record Button Replacement: passo 11, imagem 2 %32
    • Re-screw the green motherboard into place and re-attach the side cover to your camcorder.
    • When the side cover is securely fastened, you have completed the Record Button replacement of your Panasonic HDC-TM15 camcorder.
Conclusão
Emma
Membro desde: 03/11/15
176 Reputação
Autoria de 1 guia
Equipe
Marist, Team 1-4, Laflen Spring 2015 Membro de Marist, Team 1-4, Laflen Spring 2015
MARS-LAFLEN-S15S1G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 272
