Ir para o conteúdo principal
Panasonic HC‑VX870 Hand Strap Replacement
O que você precisa
  1. Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: passo 1, imagem 1 %32 Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: passo 1, imagem 2 %32 Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: passo 1, imagem 3 %32
    • Unscrew the J1 screws on the left side of the camcorder.
    • Unscrew the marked screws on the bottom of the camcorder.
    • Unscrew the marked screws on the back of the camcorder.
  2. Panasonic HC‑VX870 Hand Strap Replacement: passo 2, imagem 1 %32 Panasonic HC‑VX870 Hand Strap Replacement: passo 2, imagem 2 %32
    • Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
  3. Panasonic HC‑VX870 Hand Strap Replacement, Record Button Mechanism: passo 3, imagem 1 %32
    • Unscrew the indicated screw.
  4. Panasonic HC‑VX870 Hand Strap Replacement: passo 4, imagem 1 %32
    • Lift up on the little tab indicated in the picture and push away from the camera in order to remove the record button.
  5. Panasonic HC‑VX870 Hand Strap Replacement: passo 5, imagem 1 %32 Panasonic HC‑VX870 Hand Strap Replacement: passo 5, imagem 2 %32 Panasonic HC‑VX870 Hand Strap Replacement: passo 5, imagem 3 %32
    • Take out the piece that that was held in place by the screw and separate the smaller piece from the larger piece.
  6. Panasonic HC‑VX870 Hand Strap Replacement, Hand Strap: passo 6, imagem 1 %32
    • Use the plastic opening tool to pry the little metal bar out of place in order to release one side of the hand strap.
  7. Panasonic HC‑VX870 Hand Strap Replacement: passo 7, imagem 1 %32
    • Unscrew the indicated screws and remove the piece it was holding in place.
  8. Panasonic HC‑VX870 Hand Strap Replacement: passo 8, imagem 1 %32
    • Repeat step 3 for this side of the strap.
  9. Panasonic HC‑VX870 Hand Strap Replacement: passo 9, imagem 1 %32
    • Pull the handle straps out of their holes to remove the strap.
Conclusão
Rebecca Maloney
Membro desde: 01/24/17
501 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-6, Banghart Winter 2017 Membro de Cal Poly, Team 13-6, Banghart Winter 2017
CPSU-BANGHART-W17S13G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 595
