Ir para o conteúdo principal
Panasonic GU87 LCD Cover removal Replacement
O que você precisa
  1. Panasonic GU87 LCD Cover removal Replacement, LCD Cover removal: passo 1, imagem 1 %32
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Panasonic GU87 LCD Cover removal Replacement: passo 2, imagem 1 %32
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
Conclusão
Van
Membro desde: 06/24/10
7 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 2-10, Johann Summer 2010 Membro de Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,599
