Ir para o conteúdo principal
Panasonic ES-RF31 Battery Replacement
O que você precisa
  1. Panasonic ES-RF31 Battery Replacement, Battery: passo 1, imagem 1 %32 Panasonic ES-RF31 Battery Replacement, Battery: passo 1, imagem 2 %32 Panasonic ES-RF31 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Loose the screw at the bottom part of the razor
  2. Panasonic ES-RF31 Battery Replacement, Removing the Backcover: passo 2, imagem 1 %32 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: passo 2, imagem 2 %32 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: passo 2, imagem 3 %32
    • Slide the cover from top to bottom
  3. Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: passo 3, imagem 1 %32 Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: passo 3, imagem 2 %32
    • Loosen these eight screws
  4. Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: passo 4, imagem 1 %32 Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: passo 4, imagem 2 %32
    • Insert an opening tool into the gap
    • Gently remove the battery cover
  5. Panasonic ES-RF31 Battery Replacement, Removing the Battery: passo 5, imagem 1 %32 Panasonic ES-RF31 Battery Replacement, Removing the Battery: passo 5, imagem 2 %32
    Very good, sehr gut
    Frank D - Responder
Conclusão
7 outras pessoas executaram este guia.
Daniel
Membro desde: 07/06/15
934 Reputação
Autoria de 2 guias
Equipe
iFixit EU Team Membro de iFixit EU Team
Staff
Membros da 46
Autoria de 1.094 guias
4 comentários
Thanks Daniel,
I followed your instructions and all went well. One thing to add: after re-assembly of the (loaded) battery my razor would not turn on. At first I thought of a bad contact, but it turned out that the razor needed a few minutes plugged into the power supply. After that it worked fine. I suspect, that the load-control hardware needs the external power to reset itself.
Cheers, Nils
Nils Kay - Responder
Hello Nils!
Thanks for the hint.
Glad to hear that your razor works again!
Greetings
Daniel - Responder
Daniel, thank you very much for instruction.
Unfortunetly, into shaver I found only 1 battery.
Because used 3.7 v element, I prepared 2 x 1.2 v batteries.
Виктор Богачёв - Responder
My razor was the Panasonic ES8103S and the disassembly process was similar. From the pictures above, the battery looks the same. My razor actually had a piece under the slide-off cover that was totally rusted so I will just buy a new one on Amazon for $50. For future reference, I would like to know where you get the replacement battery? There is no model number on the battery and I couldn’t find any info online.
David Paul - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 25
Últimos 30 dias: 90
Duração total: 5,837
