Introdução
Diese Anleitung zeigt dir, wie man die Batterie eines Panasonic ES-RF31 Rasierers wechselt. Mehr Informationen zum Produkt:
O que você precisa
Führe ein Öffnungswerkzeug in den Spalt ein
Nun kann die Batterieabdeckung vorsichtig aufgehebelt werden
Entferne vorsichtig die Batterie
Um das Gerät zusammen zubauen, führe die Anleitungsschritte in umgekehrter Reihenfolge durch
7 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Daniel está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
4 comentários
Thanks Daniel,
I followed your instructions and all went well. One thing to add: after re-assembly of the (loaded) battery my razor would not turn on. At first I thought of a bad contact, but it turned out that the razor needed a few minutes plugged into the power supply. After that it worked fine. I suspect, that the load-control hardware needs the external power to reset itself.
Cheers, Nils
Daniel, thank you very much for instruction.
Unfortunetly, into shaver I found only 1 battery.
Because used 3.7 v element, I prepared 2 x 1.2 v batteries.
My razor was the Panasonic ES8103S and the disassembly process was similar. From the pictures above, the battery looks the same. My razor actually had a piece under the slide-off cover that was totally rusted so I will just buy a new one on Amazon for $50. For future reference, I would like to know where you get the replacement battery? There is no model number on the battery and I couldn’t find any info online.
