Ir para o conteúdo principal
Panasonic ER430K Battery Replacement
O que você precisa
  1. Panasonic ER430K Battery Replacement, Battery: passo 1, imagem 1 %32 Panasonic ER430K Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the battery cover by rotating it counter -clockwise and lifting it off.
    • Tilt the trimmer to the bottom, you will notice the battery housing.
  2. Panasonic ER430K Battery Replacement: passo 2, imagem 1 %32
    • Insert the AA Battery according to the terminals on the Battery housing.
    • Note the '+' side in the the housing and the '-' side on the cover.
  3. Panasonic ER430K Battery Replacement: passo 3, imagem 1 %32
    • Twist the battery cover housing in a clockwise direction to secure the the battery.
Conclusão
Dileep Balaji
Membro desde: 09/26/15
276 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S22-G2, Bayer Fall 2017 Membro de IUPUI, Team S22-G2, Bayer Fall 2017
IUPUI-BAYER-F17S22G2
Membros da 4
Autoria de 3 guias
2 comentários
Battery + side goes in first (when battery is inserted correctly, the - side will be facing you).
Marc2 Salvisberg - Responder
i prided the negative tab on the cover up to make contact. the trimmer roared to life again!
Dean Jarvis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 67
Duração total: 4,439
