Introdução
Is your blade not spinning when you turn on your device, even when you hear the motor run? Check out this guide to replace your motor shaft.
O que você precisa
Quase terminado!
Conclusão
2 comentários
Thank you, small parts where switch is could be shown as well. Would be very helpful.
Advise for putting things back together: remove plastic switch cover and put back only after full reassembly
