Ir para o conteúdo principal
Panasonic ER-GN30-K Motor Replacement
O que você precisa
  1. Panasonic ER-GN30-K Motor Replacement, Motor: passo 1, imagem 1 %32
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Replacement: passo 2, imagem 1 %32
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Replacement: passo 3, imagem 1 %32
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Replacement: passo 4, imagem 1 %32
    • Use a metal spudger to pry apart the silver plastic case.
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Replacement: passo 5, imagem 1 %32
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Replacement: passo 6, imagem 1 %32
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Replacement: passo 7, imagem 1 %32 Panasonic ER-GN30-K Motor Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
  8. Panasonic ER-GN30-K Motor Replacement: passo 8, imagem 1 %32
    • Remove the motor from the case by sliding the cover off of it.
Conclusão
6 outras pessoas executaram este guia.
Corey Tappan
Membro desde: 08/27/15
209 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 15-3, Blackwell Fall 2015 Membro de USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Membros
Autoria de 10 guias
2 comentários
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - Responder
Thanks for such a detailed step by step to disassemble. It appears that the motor is not functioning: LD-050FF-2043V motor. But I was not able to find a replacement on the internet. Any suggestions?
David Freedman - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 40
Últimos 30 dias: 67
Ao todo: 3,947
