Ir para o conteúdo principal
Panasonic ER-GN30-K Blade Replacement
  1. Panasonic ER-GN30-K Blade Replacement, Blade: passo 1, imagem 1 %32
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Blade Replacement: passo 2, imagem 1 %32
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  3. Panasonic ER-GN30-K Blade Replacement: passo 3, imagem 1 %32
    • Remove the blade from the cap by gently pulling it from the cap.
    • Even if the blade is dull or broken, it will still be sharp enough to cut skin, so be careful while you remove it.
Conclusão
5 outras pessoas executaram este guia.
Jacob Hoofman
Membro desde: 09/03/15
413 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 15-3, Blackwell Fall 2015 Membro de USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Membros
Autoria de 10 guias
6 comentários
Looked everywhere...anybody know where to get replacement blades for the Panasonic ER-GN30 nose & ear trimmer?
R Holmes - Responder
Did you ever find a replacement blade?
PCARRINGTON - Responder
I called Panasonic's support number, and supposedly the inner blade at least, is priced from around $14 to $20, from various places. Considering major resellers have the whole trimmer for around $12, it would not make sense to get just a blade. Amazon has open-box wearhouse deals now, where the trimmers can be had for under $5.00. I may get one of these myself :)
Jim Locke - Responder
Hola yo acabo de comprar las cuchillas a 7€ , les dejo el enlace https://juanluismartel.com ademas me repararon una camara Panasonic Lumix, Gracias.
usblsb - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 72
Ao todo: 13,559
