Ir para o conteúdo principal
Panasonic DMP-BD89 Wifi Board Replacement
O que você precisa
  1. Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: passo 1, imagem 1 %32 Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: passo 1, imagem 2 %32
    • First, before powering off, press the eject button to open the tray.
  2. Panasonic DMP-BD89 Wifi Board Replacement: passo 2, imagem 1 %32 Panasonic DMP-BD89 Wifi Board Replacement: passo 2, imagem 2 %32 Panasonic DMP-BD89 Wifi Board Replacement: passo 2, imagem 3 %32
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
  3. Panasonic DMP-BD89 Wifi Board Replacement: passo 3, imagem 1 %32 Panasonic DMP-BD89 Wifi Board Replacement: passo 3, imagem 2 %32
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
  4. Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: passo 4, imagem 1 %32 Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: passo 4, imagem 2 %32
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
  5. Panasonic DMP-BD89 Wifi Board Replacement: passo 5, imagem 1 %32
    • Slide the top panel horizontally to remove it.
  6. Panasonic DMP-BD89 Wifi Board Replacement: passo 6, imagem 1 %32 Panasonic DMP-BD89 Wifi Board Replacement: passo 6, imagem 2 %32 Panasonic DMP-BD89 Wifi Board Replacement: passo 6, imagem 3 %32
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
  7. Panasonic DMP-BD89 Wifi Board Replacement: passo 7, imagem 1 %32
    • Pop the 6 markers out.
    • Then take off the cover.
  8. Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: passo 8, imagem 1 %32 Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: passo 8, imagem 2 %32
    • Locate reddish brown cable. Detach from green circuit board by pulling upward.
  9. Panasonic DMP-BD89 Wifi Board Replacement: passo 9, imagem 1 %32
    • Using tweezer, compress the white knob holding the wifi module board in place.
  10. Panasonic DMP-BD89 Wifi Board Replacement: passo 10, imagem 1 %32 Panasonic DMP-BD89 Wifi Board Replacement: passo 10, imagem 2 %32
    • Pull the module board straight up, removing completely. The second photo is how your device should look with the WiFi board removed.
Conclusão
Uma outra pessoa concluiu este guia.
Mohan Saxena
Membro desde: 10/17/17
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 404
