Ir para o conteúdo principal
Panasonic DMP-BD89 Exterior Cover Replacement
O que você precisa
  1. Panasonic DMP-BD89 Exterior Cover Replacement, Disk Tray Cover: passo 1, imagem 1 %32 Panasonic DMP-BD89 Exterior Cover Replacement, Disk Tray Cover: passo 1, imagem 2 %32
    • First, before powering off, press the eject button to open the tray.
  2. Panasonic DMP-BD89 Exterior Cover Replacement: passo 2, imagem 1 %32 Panasonic DMP-BD89 Exterior Cover Replacement: passo 2, imagem 2 %32 Panasonic DMP-BD89 Exterior Cover Replacement: passo 2, imagem 3 %32
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
  3. Panasonic DMP-BD89 Exterior Cover Replacement: passo 3, imagem 1 %32 Panasonic DMP-BD89 Exterior Cover Replacement: passo 3, imagem 2 %32
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
  4. Panasonic DMP-BD89 Exterior Cover Replacement, Exterior Cover: passo 4, imagem 1 %32 Panasonic DMP-BD89 Exterior Cover Replacement, Exterior Cover: passo 4, imagem 2 %32
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
  5. Panasonic DMP-BD89 Exterior Cover Replacement: passo 5, imagem 1 %32
    • Slide the top panel horizontally to remove it.
  6. Panasonic DMP-BD89 Exterior Cover Replacement: passo 6, imagem 1 %32 Panasonic DMP-BD89 Exterior Cover Replacement: passo 6, imagem 2 %32 Panasonic DMP-BD89 Exterior Cover Replacement: passo 6, imagem 3 %32
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
  7. Panasonic DMP-BD89 Exterior Cover Replacement: passo 7, imagem 1 %32
    • Pop the 6 markers out.
    • Then take off the cover.
Conclusão
David Sun
Membro desde: 10/17/17
213 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 265
