1. Remove Strap and battery Remove bottom 3 screws. Remove side panel screws from both sides of the unit. Total of 4 screws.
    • Remove Strap and battery
    • Remove bottom 3 screws.
    • Remove side panel screws from both sides of the unit. Total of 4 screws.
  2. Remove both side panels.  You can use your fingernails or a spudger. Remove both side panels.  You can use your fingernails or a spudger.
    • Remove both side panels. You can use your fingernails or a spudger.
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Pry off rear cover. Make sure LCD remains in place. There is a thin film of adhesive attaching the LCD to the rear cover.  It releases easily with a little pressure. If necessary hold the LCD in place while removing the rear cover. Remove front cover.
    • Pry off rear cover. Make sure LCD remains in place.
    • There is a thin film of adhesive attaching the LCD to the rear cover. It releases easily with a little pressure. If necessary hold the LCD in place while removing the rear cover.
    • Remove front cover.
  5. Use tweezers to push the rod Up a bit. Use tweezers to pull the rod all the way  up until the door releases.  Do not remove the rod.. let the end remain in the hole. To install the new door use a small piece of tape to hold the spring in place on the door. Make sure it is positioned as shown in the picture. Make sure none of the tape interferes with the doors operation during installment.
    • Use tweezers to push the rod Up a bit.
    • Use tweezers to pull the rod all the way up until the door releases. Do not remove the rod.. let the end remain in the hole.
    • To install the new door use a small piece of tape to hold the spring in place on the door. Make sure it is positioned as shown in the picture. Make sure none of the tape interferes with the doors operation during installment.
  6. Install the new door Part # VYK4T91.  Line up the spring tongue with the groove inside the battery compartment. Line up the spring with the rod and push down the rod.  You are done!! Reverse the steps to put the camera back together.
    • Install the new door Part # VYK4T91. Line up the spring tongue with the groove inside the battery compartment.
    • Line up the spring with the rod and push down the rod. You are done!! Reverse the steps to put the camera back together.
Conclusão
Sales Cameraparts4you
2.509 reputação
20 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 26
