Ir para o conteúdo principal
Panasonic DMC-FZ70 Back Frame Replacement
O que você precisa
  1. Panasonic DMC-FZ70 Back Frame Replacement, Back Panel: passo 1, imagem 1 %32 Panasonic DMC-FZ70 Back Frame Replacement, Back Panel: passo 1, imagem 2 %32
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
  2. Panasonic DMC-FZ70 Back Frame Replacement: passo 2, imagem 1 %32 Panasonic DMC-FZ70 Back Frame Replacement: passo 2, imagem 2 %32
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
  3. Panasonic DMC-FZ70 Back Frame Replacement: passo 3, imagem 1 %32 Panasonic DMC-FZ70 Back Frame Replacement: passo 3, imagem 2 %32
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
  4. Panasonic DMC-FZ70 Back Frame Replacement: passo 4, imagem 1 %32 Panasonic DMC-FZ70 Back Frame Replacement: passo 4, imagem 2 %32
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
  5. Panasonic DMC-FZ70 Back Frame Replacement: passo 5, imagem 1 %32
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
  6. Panasonic DMC-FZ70 Back Frame Replacement: passo 6, imagem 1 %32
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
  7. Panasonic DMC-FZ70 Back Frame Replacement: passo 7, imagem 1 %32 Panasonic DMC-FZ70 Back Frame Replacement: passo 7, imagem 2 %32 Panasonic DMC-FZ70 Back Frame Replacement: passo 7, imagem 3 %32
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
  8. Panasonic DMC-FZ70 Back Frame Replacement, LCD Screen: passo 8, imagem 1 %32 Panasonic DMC-FZ70 Back Frame Replacement, LCD Screen: passo 8, imagem 2 %32
    • Unscrew the five 5mm screws on the panel that you just removed.
  9. Panasonic DMC-FZ70 Back Frame Replacement: passo 9, imagem 1 %32 Panasonic DMC-FZ70 Back Frame Replacement: passo 9, imagem 2 %32
    • Remove the entire silver panel to reveal the back of the LCD screen
  10. Panasonic DMC-FZ70 Back Frame Replacement: passo 10, imagem 1 %32
    • Remove the LCD screen.
  11. Panasonic DMC-FZ70 Back Frame Replacement, Back Frame: passo 11, imagem 1 %32
    • You can now access the back panel and the buttons on it.
  12. Panasonic DMC-FZ70 Back Frame Replacement: passo 12, imagem 1 %32
    • To remove a button, lightly press its front face and it should detach with ease.
    • To put a button back into the camera, press on front its back face until it snaps back on.
Conclusão
Emily Kuzmicky
Membro desde: 01/24/17
445 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 21-3, Maness Winter 2017 Membro de Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
Membros da 6
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 953
