Ir para o conteúdo principal
Panasonic DECT 6.0 Button Replacement
O que você precisa
  1. Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: passo 1, imagem 1 %32 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: passo 1, imagem 2 %32 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: passo 1, imagem 3 %32
    • Remove the battery cover by pushing the tab upwards and sliding it off.
    • Pull out the battery/energy source from its slot.
    • Keep all pieces in a safe and orderly manner for ease of reassembly.
    Pergunte ao FixBot
  2. Panasonic DECT  6.0 Button Replacement: passo 2, imagem 1 %32 Panasonic DECT  6.0 Button Replacement: passo 2, imagem 2 %32 Panasonic DECT  6.0 Button Replacement: passo 2, imagem 3 %32
    • Unscrew the screws you see on the inside of the casing using an appropriate screwdriver from the JIS Driver Set.
    • Carefully pry each side open with the iFixit Opening tool.
    • Detach the back of the phone case.
    Pergunte ao FixBot
  3. Panasonic DECT  6.0 Button Replacement: passo 3, imagem 1 %32 Panasonic DECT  6.0 Button Replacement: passo 3, imagem 2 %32 Panasonic DECT  6.0 Button Replacement: passo 3, imagem 3 %32
    • Unscrew the screws to remove the motherboard using an appropriate screwdriver from the JIS Driver Set.
    • Potential for device damage
    Pergunte ao FixBot
  4. Panasonic DECT  6.0 Button Replacement: passo 4, imagem 1 %32 Panasonic DECT  6.0 Button Replacement: passo 4, imagem 2 %32 Panasonic DECT  6.0 Button Replacement: passo 4, imagem 3 %32
    • Carefully pull off the circuitry and cords from the front half of the phone and set them aside.
    • Bring the buttons to the front.
    Pergunte ao FixBot
  5. Panasonic DECT  6.0 Button Replacement: passo 5, imagem 1 %32 Panasonic DECT  6.0 Button Replacement: passo 5, imagem 2 %32
    • Pull gently to separate the button pad from the phone cover.
    • Identify the broken/jammed button you were having issues with.
    • Replace or return the button to its function.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
Jacob
Membro desde: 05/31/16
131 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 48
Ao todo: 880
