Ir para o conteúdo principal
Panasonic Compact Shaver ES4815 Motor Replacement
O que você precisa
  1. Panasonic Compact Shaver ES4815 Motor Replacement, Battery: passo 1, imagem 1 %32 Panasonic Compact Shaver ES4815 Motor Replacement, Battery: passo 1, imagem 2 %32 Panasonic Compact Shaver ES4815 Motor Replacement, Battery: passo 1, imagem 3 %32
    • Twist the release cap to expose the batteries.
  2. Panasonic Compact Shaver ES4815 Motor Replacement: passo 2, imagem 1 %32 Panasonic Compact Shaver ES4815 Motor Replacement: passo 2, imagem 2 %32
    • Remove the batteries.
  3. Panasonic Compact Shaver ES4815 Motor Replacement, Motor: passo 3, imagem 1 %32 Panasonic Compact Shaver ES4815 Motor Replacement, Motor: passo 3, imagem 2 %32 Panasonic Compact Shaver ES4815 Motor Replacement, Motor: passo 3, imagem 3 %32
    • Remove the razor guard by pushing its release buttons and pulling.
  4. Panasonic Compact Shaver ES4815 Motor Replacement: passo 4, imagem 1 %32 Panasonic Compact Shaver ES4815 Motor Replacement: passo 4, imagem 2 %32 Panasonic Compact Shaver ES4815 Motor Replacement: passo 4, imagem 3 %32
    • Carefully pull out the inner blades.
  5. Panasonic Compact Shaver ES4815 Motor Replacement: passo 5, imagem 1 %32 Panasonic Compact Shaver ES4815 Motor Replacement: passo 5, imagem 2 %32 Panasonic Compact Shaver ES4815 Motor Replacement: passo 5, imagem 3 %32
    • Remove the two 1.9mm Phillips #0 screws from the inner blades.
  6. Panasonic Compact Shaver ES4815 Motor Replacement: passo 6, imagem 1 %32 Panasonic Compact Shaver ES4815 Motor Replacement: passo 6, imagem 2 %32
    • Remove the metal plate.
  7. Panasonic Compact Shaver ES4815 Motor Replacement: passo 7, imagem 1 %32 Panasonic Compact Shaver ES4815 Motor Replacement: passo 7, imagem 2 %32 Panasonic Compact Shaver ES4815 Motor Replacement: passo 7, imagem 3 %32
    • Pull the outer casing with one hand while holding the inner battery casing with the other hand.
  8. Panasonic Compact Shaver ES4815 Motor Replacement: passo 8, imagem 1 %32 Panasonic Compact Shaver ES4815 Motor Replacement: passo 8, imagem 2 %32
    • Detach the white plastic blade base from the tip of the motor by pulling it.
  9. Panasonic Compact Shaver ES4815 Motor Replacement: passo 9, imagem 1 %32 Panasonic Compact Shaver ES4815 Motor Replacement: passo 9, imagem 2 %32
    • Detach motor from gray plastic holder by pulling it.
Conclusão
muhammad samsulsham
Membro desde: 05/21/18
253 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G5, Harley Spring 2018 Membro de IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
Membros da 6
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 509
