Ir para o conteúdo principal
Panasonic Camera DMC-FX07 Battery Replacement
  1. Panasonic Camera DMC-FX07 Battery Replacement, Battery: passo 1, imagem 1 %32 Panasonic Camera DMC-FX07 Battery Replacement, Battery: passo 1, imagem 2 %32
    • The first step is to turn off the camera
    • Next, locate the battery door on the bottom of the camera
    • To open, slide the latch left, or towards the tripod mount
    • The door should spring open
  2. Panasonic Camera DMC-FX07 Battery Replacement: passo 2, imagem 1 %32 Panasonic Camera DMC-FX07 Battery Replacement: passo 2, imagem 2 %32 Panasonic Camera DMC-FX07 Battery Replacement: passo 2, imagem 3 %32
    • Now that the door is open, release the spring clip on the right
    • The battery should pop out just enough so you can pull it out
    • Pull the battery out.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 1,224
