Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will show you how to replace the door covering the battery compartment. Overall this guide does not take much knowledge regarding disassembly, however you should take care to remember how the parts are situated before removing them.
Peças
Nenhum componente especificado.
  1. Set the switch on the battery door to "open," and open the door. Set the switch on the battery door to "open," and open the door.
    • Set the switch on the battery door to "open," and open the door.
  2. At the left hand side, locate the head of the metal bar that holds the spring in place.
    • At the left hand side, locate the head of the metal bar that holds the spring in place.
  3. Push the metal bar down using the metal tweezers.
    • Push the metal bar down using the metal tweezers.
  4. Pull the metal bar that holds the spring in place out.
    • Pull the metal bar that holds the spring in place out.
    • You can also use tweezers for this step, although we found it easier to just use our fingers.
  5. Remove the battery access door from the device.
    • Remove the battery access door from the device.
    • In order to keep the "springiness" of the door, be sure that the long arm of the spring is not over the hole for the battery.
Conclusão
Zhentao
Membro desde: 30-01-2018
247 Reputation
2 Guias de autoria
Equipe
Baylor, Team S2-G3, Johnson Spring 2018 Membro de Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 Membros
6 Guias de autoria
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 70
