Ir para o conteúdo principal
Panasonic CF-31 Toughbook Keyboard Replacement
O que você precisa
  1. Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: passo 1, imagem 1 %32 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: passo 1, imagem 2 %32 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: passo 1, imagem 3 %32
    • Open the battery compartment by pulling the tab forward and then down.
    • Open the compartment door by pushing down.
    • Use the plastic tab to pull the battery out of the compartment.
  2. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 2, imagem 1 %32 Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 2, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the three screws from the bezel.
    • Use a nylon spudger to remove the bezel.
  3. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 3, imagem 1 %32 Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 3, imagem 2 %32
    • Use a nylon spudger to lift each corner of the keyboard.
    • Use your hands and gently pull back to remove the keyboard.
  4. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 4, imagem 1 %32 Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 4, imagem 2 %32
    • Use a Phillips # 2 screwdriver to remove the four screws securing the keyboard shield.
    • Remove the keyboard shield.
  5. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 5, imagem 1 %32
    • Remove the top left ribbon cable using a nylon spudger to pull the top and bottom tabs right.
  6. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 6, imagem 1 %32
    • Remove the top right ribbon cable using a nylon spudger and push the top and bottom tabs left.
  7. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 7, imagem 1 %32 Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 7, imagem 2 %32
    • Remove the bottom left ribbon cable using a nylon spudger and push the top and bottom tabs right.
Conclusão
To reassemble the Panasonic CF-31 Toughbook Laptop, follow these instructions in reverse order.
Richard Gill
Membro desde: 01/16/19
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 32
Duração total: 2,733
